6th Gen ('00-'05): Turn Signal Trouble?
Old Aug 30, 2014 | 08:40 AM
michelob's Avatar
Default Turn Signal Trouble?
2001 Monte Carlo SS
OK this has me perplexed....
The other day my turn signal started doing some strange things like blinking really fast with a "clicking" coming from the dash around the hazard light switch. So I checked all the lights and I noticed the front driver side and rear passenger side markers were burned out. So I replaced those bulbs. Now the "clicking" hasn't come back but the turn signal is still not quite illuminating right. It seems slower than normal and not the usual turn signal "sound" when I got out and looked my side markers weren't working....even the bulbs I just replaced? LOL
Now it is intermittent in that when I drive it in a few hours its likely to all work correctly. So whats the opinion on this? Bad turn signal switch in the steering column? Bad hazard switch? Bad wiring?
Thanks guys.
Old Aug 30, 2014 | 08:49 AM
Could be a bad Multifunction switch.
1 way to check it...
Have a friend "Jiggle" the turn signal switch. Watch the Tail lights and turn signals
If they start flickering you have a bad multifunction control switch.
Old Aug 30, 2014 | 08:54 AM
michelob's Avatar
Have a friend "Jiggle" the turn signal switch and see if the lights (Tail and turn signals)
OK will do. The "multifunction switch" is that the turn signal switch that also has like my wipers on it too? So it could be the switch that "runs" all that then is what you are saying?
Old Aug 30, 2014 | 08:55 AM
Yes..
Old Aug 30, 2014 | 12:00 PM
michelob's Avatar
If it turns out to be that switch is there any reason to go with a $200 switch as opposed to a $35 one on Ebay? I replaced my Olds with a cheap one once and it worked fine.
Old Aug 30, 2014 | 06:44 PM
owens91's Avatar
I got a 35 dollars one off ebay around last year so far no issues
Old Aug 31, 2014 | 04:47 PM
michelob's Avatar
Excellent thanks for the confirmation.
trey0503
Apr 27, 2018 11:39 AM
turner_dtp
Feb 24, 2007 12:55 PM
djizzle
Jan 19, 2007 01:05 PM
Nortybignort
Jul 25, 2006 10:35 PM
Lee55
Jun 9, 2006 09:20 AM
