turn signal problems
Old Jun 25, 2011 | 10:17 AM
dkeizer05's Avatar
I find it pretty frustrating that these hazard switches go bad on the Monte. I had this problem years ago, like in 2002 on my 01 Monte. Now yesterday the got-damned thing is acting up again.
I mean I hit that switch all of once every 2 years.
Old Aug 4, 2014 | 02:40 PM
wertio12's Avatar
i had the same problem buzzing it was the ignition switch
Old Aug 8, 2014 | 12:34 PM
gprtech's Avatar
I replaced the original switch with a Dorman replacment. The original switches were just designed badly. I'm hoping the Dorman version is better.
Old Aug 19, 2014 | 07:53 AM
WendyCGP's Avatar
Yes I need to take apart my dash the easy way, any video's for that? I'm not a mechanic.
Old Oct 21, 2015 | 02:12 PM
cherokee727's Avatar
Default monte carlo
I have issue with my turn signals they work till i put in gear then the high beam out light comes on then turn signals flash fast and both sides flash as well checked all light bulbs put a flasher switch in and a turn signal switch in same thing
Old Oct 27, 2015 | 08:12 PM
scottschevy72's Avatar
Have same problem. Nobody knows how to fix. I've changed emergency switch two times. If you find answer please share. Someone out there must know something...
Old Jan 27, 2017 | 01:45 PM
Dvyasa79's Avatar
Default '03 Monte Carlo SS blinkers work fine while day running lights and normal lights are
bkinkers work fine while day running lights and normal headlights are off..once headlamps are in blinkers in front and rear blink rapidly and dimly. Any idea what could be causing with this??
Old Jan 27, 2017 | 02:07 PM
Dvyasa79's Avatar
'03 MC SS..bkinkers work fine while day running lights and normal headlights are off..once headlamps are in blinkers in front and rear blink rapidly and dimly. Any idea what could be causing with this??
Old Dec 31, 2019 | 03:59 PM
Brandon Starnes's Avatar
Its a ground issue by the head light drivers side find it and file the paint off and put back should fix your issue
Old Oct 20, 2025 | 01:08 PM
maxfpsoffset's Avatar
hey sorry to bump such a old thread, but my ls has started acting up like this,.would it be ground for the headlamps or ground for the exterior lamp switch?
