6th Gen ('00-'05): Turn Signal stuck in position
Old Jun 19, 2019 | 03:44 PM
FatalcMCSS's Avatar
Default Turn Signal stuck in position
Hey, I just replaced my Multifunction Switch and my Hazard Flasher Switch and turn signals themselves and hazard lights work fine..but it's when I make a Left turn and flip my switch to go that way, when I make the turn, the **** doesn't click back into original position, it clicks but sticks and I have to manually put it back in position by hand.
Any way to fix this or is it a problem with the Multifunction switch?? (Right turns work like supposed to)
Old Jul 12, 2019 | 01:47 PM
volkerc's Avatar
usually a broken spring
Old Jul 17, 2019 | 05:38 PM
FatalcMCSS's Avatar
Inside the actual multifunction switch, isn't it?
Old Jul 18, 2019 | 03:30 AM
volkerc's Avatar
Yes, there are two springs. you can buy just the springs.
Old Jul 19, 2019 | 11:06 PM
FatalcMCSS's Avatar
Do you where and what kind of springs to buy? If you can post an i.age will be a huge help
Dj_bosse
Jul 8, 2016 05:58 AM
wkimes
Jun 3, 2015 07:29 PM
michelob
Aug 31, 2014 04:47 PM
RickCoMatic
Jan 20, 2013 08:57 AM
robertspangler
Jan 8, 2009 09:54 PM
