turn signal help
turn signal help
ok so my girlfriends 2000 ls has been having turn signal problems for a while. It started out they wouldn't work randomly but if you turned the flashers on with the signal then back off they would. eventually that stopped working so now she has no signals at all. Any ideas?
RE: turn signal help
Check the fuses.
Replace the Flasher with a new one. They're cheap.
Pray it ain't the Switch, 'cause that Switch Assy is a wallet-breaking moe-foe!
See if you can find a used one if the Switch is bad.
You can remove the Switch without removing the Steering Wheel. I used a Small Torx Bit epoxied into the closed end of a small box wrench. Bingo.
Skeletal Crow
07-22-2011 11:56 AM
djizzle
01-19-2007 01:05 PM
