turn signal help
Old Jan 6, 2009 | 12:47 PM
2000lsman's Avatar
Default turn signal help
ok so my girlfriends 2000 ls has been having turn signal problems for a while. It started out they wouldn't work randomly but if you turned the flashers on with the signal then back off they would. eventually that stopped working so now she has no signals at all. Any ideas?
Old Jan 6, 2009 | 09:25 PM
kweef's Avatar
Default RE: turn signal help
flasher module
Old Jan 6, 2009 | 10:30 PM
RickCoMatic's Avatar
Check the fuses.
Replace the Flasher with a new one. They're cheap.
Pray it ain't the Switch, 'cause that Switch Assy is a wallet-breaking moe-foe!
See if you can find a used one if the Switch is bad.
You can remove the Switch without removing the Steering Wheel. I used a Small Torx Bit epoxied into the closed end of a small box wrench. Bingo.
Old Jan 7, 2009 | 03:09 PM
2000lsman's Avatar
where is the flasher module located and is it just like the old school ones? i don't kow much about newer cars
Old Jan 7, 2009 | 03:50 PM
Cut Throat's Avatar
They can be under or in the stearing colum. It is a real PITA to get at if thats where it is on your car.
trey0503
Apr 27, 2018 11:39 AM
Skeletal Crow
Jul 22, 2011 11:56 AM
djizzle
Jan 19, 2007 01:05 PM
Nortybignort
Jul 25, 2006 10:35 PM
Lee55
Jun 9, 2006 09:20 AM
