96 3.1 coolant leak
Old Dec 2, 2008 | 01:59 PM
rrman99's Avatar
Default 96 3.1 coolant leak
i have replaced the radiator,water pump and intake gasket. still losing water cant find the leak.when the temp gauge goes up lose heat from the vents,reving motor drops temp and heat comes back through vents.
Old Jan 3, 2009 | 09:13 PM
ng4thraider's Avatar
Default RE: 96 3.1 coolant leak
I am going througha similarproblem with my 95 3.1, I am not losing any coolant but am experiencing high temp during idle. I rev the engine and the temp drops. I replaced the intake gasket, radiator cap, and thermostat. If you find the solution could you post it or email me.
Could it be the low speed cooling fan?
Old Jan 3, 2009 | 09:23 PM
sandmanxxx's Avatar
as far as it goes refer to the owners manual for properly bleeding the coolant system you might not b loosing water at all and as far as it running hot when not revving the engine possibly a low speed cooling fan or a relay or possibly just the coolant not being properly bleed
Old Jan 7, 2009 | 02:35 PM
SpaceAce's Avatar
Sandmanxxx is probably on the right track. I had the same type of thing going on and found that I had a huge air gap somewhere in the system. OnceI cleared the air everything was fine. I opened the air release screw (near the thermo neck) and ran the engine until warm, while at the same time squeezing the upper and lower rad hoses until the air pocket was forced out the rad neck (I also left the rad cap off during this process).
Old Jan 7, 2009 | 03:56 PM
Cut Throat's Avatar
SpaceAge, I just got done doing that to my 98 LS last weekend. Mine had all the same problems listed above, and if done correctly it will fix the problem.
MonteSquarlo
Dec 16, 2012 06:18 PM
2000LS
Jan 28, 2008 08:00 PM
autonoz
Dec 28, 2006 12:27 AM
orthokneepa
Sep 14, 2006 07:59 PM
greg fell
Jul 19, 2006 10:59 PM
