Opinion Needed: trouble with fuel system
Old May 31, 2015 | 12:27 PM
Scott Peters's Avatar
Default trouble with fuel system
have a 2003 monte carlo ss it will start and run fine then shortly afterwards it will shut down like it is not getting fuel let it set 4 or 5 hours it will start and do the same thing any ideas
Old May 31, 2015 | 12:54 PM
plumbob's Avatar
Sounds like either a clogged fuel filter, or more likely, the fuel pump. If you have access to a fuel pressure gauge, connect it to the Schrader valve on the front side of the fuel rail. With the key on the "On" position the pressure should be around 55 psi. Then start the engine, pressure should only vary 1-2 psi regardless of RPM's.
Old May 31, 2015 | 01:01 PM
Thanks that is what I thought my next question is where would the fuel filter be located
Old May 31, 2015 | 01:05 PM
plumbob's Avatar
Filter is just behind and under the driver side door along the frame rail. Has quick connects. Be careful if you see rust/corrosion around the connections.
Old May 31, 2015 | 01:07 PM
Ok thanks you have been very helpful. :-)
Old May 31, 2015 | 01:09 PM
plumbob's Avatar
Good luck, keep us posted.
Old Jun 1, 2015 | 10:43 PM
nitehawkjcb's Avatar
Could be a crank sensor or ICM failing also
JaxJim
Sep 18, 2010 08:24 PM
02montecarlo
Jul 14, 2010 08:08 AM
02montecarlo
Jul 7, 2010 11:41 AM
aussiek2000
Feb 27, 2009 07:31 AM
J_Bru_Ha_SS
Aug 16, 2006 04:03 PM
