Traction Control Went Out
I was driving and all of a sudden the Trac Off light comes on, and the message center is telling me to service the traction control system. There is no check engine light or code. What could have happened?
Did the ABS light also come on?
Odds are it is probably a wheel speed sensor. There is definately a code, but you need a code reader that will access the EBCM (most code readers only check the PCM).
2003supersport
Dec 14, 2009 03:46 PM
