ses/traction control goes off
Old Dec 10, 2009 | 08:42 PM
2003supersport's Avatar
Photobucket
Monte Of The Month -- May 2009
Default ses/traction control goes off
it doesnt happen all the time, just randomly and not too often. sometimes i'll start up my car, and my ses light will flash and shut my traction control off. if i shut the car off and restart it, it goes away. anyone ever seen this before?
could it be at any way related to my transmission? been having problems with it recently, especially with the 1-2 shift and the upshifts.
Old Dec 11, 2009 | 10:14 AM
Does the ABS light come on also? Because if it does then...
My guess would be a wheel hub assembly is starting to go bad. Tons of sensors in there that go, and then you have to replace the whole assembly.
If you can get the ABS code scanned it should tell you which is starting to fail.
Old Dec 12, 2009 | 10:03 PM
Photobucket
havent seen it on in a while, and no the abs light does not come on. wierd huh.
my latest code was a p1133, but that was from my new oxygen sensor. cleared the code and hasnt shown up since. replaced the oxygen sensor when i installed my pacesetters yesterday.
i just wanna check to make sure, that way i can start saving for a replacement of whatever it is when it completely dies lol. i did scan to see if it threw a code when the light came on, but it showed no faults. just the ses light came on and the traction control shut off. tried to turn it back on by pushing the button, but didnt do anything. it stayed off. shut the car off, turn it back on and everything is back to normal. hasnt done it in about a week and a half though. does it periodically.
Old Dec 14, 2009 | 08:46 AM
Check all your wiring?
Old Dec 14, 2009 | 03:02 PM
Photobucket
havent yet. probably will on wednesday, my next day off. see what happens.
Old Dec 14, 2009 | 03:14 PM
03SS/00GSE/93LX's Avatar
Sounds like a speed sensor in one of your hubs is going bad. A dealership with a GM Tech II should be able to tell you which hub's sensor is faulting.
Old Dec 14, 2009 | 03:46 PM
But not having the ABS light go off to, made me think otherwise?
mwmarshall
May 14, 2022 02:43 AM
can2tx
Nov 18, 2013 02:20 PM
Leprechaun93
14
Mar 30, 2013 08:53 PM
Chris s
Jan 27, 2013 04:30 PM
Jul 8, 2012 08:27 AM
