TPM issues
Old Jan 9, 2011 | 11:56 PM
blackbeauty89's Avatar
Default TPM issues
Today i was driving on the interstate and all of a sudden my "low tire pressure" message shows up. i stop to check all the pressures and they're at 32psi. soo....i'm assuming there's a fault in one of the sensors and i'll need to replace it to shut the light off. anybody know a lot about GM tpm's?
Old Jan 10, 2011 | 11:08 AM
biggriggs's Avatar
You can access the menu to reset the error message through the stock radio, in case it was just a glitch that caused it to set.
Otherwise, the TPMS is based through the ABS sensors, which just detect a difference in wheel speed to determine a difference in tire pressure.
Best of luck,
-Riggs.
Jparks
Feb 25, 2014 07:09 PM
mayerichm
Mar 3, 2006 11:16 AM
jsteezy129
Nov 15, 2005 10:47 PM
jsteezy129
Nov 15, 2005 10:14 PM
GTown
Nov 11, 2005 11:27 PM
