having a missfire again
Old Jan 6, 2011 | 08:36 AM
monte07's Avatar
Default having a missfire again
it has been almost a year and it poped up again i have the dealer replace the coil pack spark plugs and wires as well as the nock sensor map sensor and the maf still no cure. i am at a loss because it still throwes a code. i am wondering if the cat is going bad to cause it but i dont want to throw unneccesary parts on the car and not fix the problem. so far i am at a loss because it is only throwing a code on one cylender insted of two or three like i had a while back. if some one can help it is apreciated my monte is a 7th gen 3500 vvt flexfuel. this is what has been done so far new fuel filter new coil pack and wires and plugs and a new air filter with all new fluid in the engine and trans also new fluid in the radiator. i am at a loss on why there is a missfire on cylender 2
Old Jan 6, 2011 | 08:48 AM
MillerMonteSS's Avatar
2010 Monte Of The Year
There could be a piece of debris in that cylinder that is creating a hot spot. I would do a compression test (just to check) followed by looking directly into the cylinder to see if anything is off. It could even be a cracked valve seat. The fact that only cylinder #2 has developed the knock, gives you a great starting point. I am not over familiar with e3 spark plugs. Are they pre-gapped? You may also want to replace just the one spark plug, in case you got a bad one. Good luck.
Old Jan 6, 2011 | 07:00 PM
monte07's Avatar
i was told by the dealer and was billed for a pressure test and had them check the valves again. because i had head gasket problems do to a recall for our v6 7th gen models. i had them replace the spark plugs when it was at the dealer but knowing my luck they build me and didnt do a f&*$ thing. right now i am looking for anouther shop to look at it. because i have anouther 100k mile warrenty and it should be covered by it. if anouther shop finds some thing wrong
Old Jan 6, 2011 | 07:03 PM
monte07's Avatar
oh the e3 comes pregaped right now i will be at work till monday before i check that cylender again as in put in anouther plug in and swap the wire.
Old Jan 6, 2011 | 07:21 PM
Good luck and let me know.
Old Jan 10, 2011 | 01:48 PM
monte07's Avatar
hay millermontess i changed out that spark plug. it cracked a little at the part where the spark plug boot and the spark blug meet and giving a grounding out. i am glad it wasent serius
Old Jan 10, 2011 | 01:49 PM
monte07's Avatar
i think it was hust a bad plugwhat i mean is make a thousand and have 1 or two of them get goofed
06LTMonte
Oct 15, 2016 09:04 PM
LittleE
Apr 8, 2015 12:31 AM
Nightmagic11801
May 12, 2014 12:15 PM
WannaMCSS
Dec 14, 2011 09:27 AM
bustedgto@live.com
Nov 30, 2010 08:04 PM
