Tire Rotation & Tire Pressure Sensors
Old Oct 27, 2006 | 08:34 PM
Greeny's Avatar
Default Tire Rotation & Tire Pressure Sensors
On the 2006 MC SS, is there a way to reset the TPS after a tire rotation. The Firestone tech put in too much tire pressure in the front left and I left out air to bring the front left even with the front right at 30 PSI. The backs were both at 31 PSI. After letting air out, the tire pressures in the front stayed the same and the rear left was down to 29. Does the sensors retain the memory of where they were previously on the car? I know this sounds like a dumb question, but I just don't see how after letting air out of the front left, your rear left is the one that shows lower pressure.
Old Oct 27, 2006 | 09:00 PM
GrandPaDave's Avatar
Default RE: Tire Rotation & Tire Pressure Sensors
ORIGINAL: Greeny
The instructions are in the owner's manual and there is a thread here with the instructions also. Just do a search.
Old Oct 28, 2006 | 12:14 AM
Greeny's Avatar
Found it in the owners manual. Thanks for the reply SolarSlayer!
Old Oct 28, 2006 | 02:21 PM
2000_BLACK_SS's Avatar
is there any way to reset the tire pressure light with an after market radio or do i have to put my stock one back in.
Old Oct 30, 2006 | 07:43 AM
04 Intimidator's Avatar
Yes it is the first paragraph on pg 6-45 of the owners manual. You can find a copy here: http://mymonte.com/tech/manuals/2000montecarlo.pdf
Basically have the key in the on position... you can do this with the car running as well.
Pull the head light switch out 1 click so the parking lights are on, then turn the button clockwise till the dome light comes on and then back so it turns off. Do this a total of 3 times. with about a 1 second pause between each one.
Old Oct 30, 2006 | 11:50 PM
thank you for your help that stupid light has been bothering me for 3 months
CoolDad64
Apr 8, 2013 07:49 AM
Mar 6, 2012 04:10 PM
Jan 26, 2009 04:36 PM
GrandPaDave
Oct 25, 2007 11:47 AM
montejass
May 10, 2005 11:24 AM
