6th Gen ('00-'05): Throttle body and vacuum line questions
Old Jun 16, 2015 | 01:15 PM
khel72's Avatar
Default Throttle body and vacuum line questions
Alright guys I'm needing help... Again. I have a 2000 project Monte that is driving me nuts. First while changing the throttle body coolant hoses I see Tb is dirty so I pull off to clean and it's a sludge mess inside. Bad enough, then I notice the vacuum hose going from the air intake duct is not connected to anything. Can't for the life of me find the name or part number for this hose. If anybody knows that would be great, and seeing how it's going into the back of the engine what else should I do? Change the oil that I just did, pull the plenum and clean it too? I'm mobile but will post pics here in a few. Thanks in advance
Old Jun 16, 2015 | 01:39 PM
khel72's Avatar
Default Pics
What is the best way to polish the throttle body?
Old Jun 16, 2015 | 09:22 PM
That hose is for the PCV system on the 3100/3400 engine. The other end goes into the back valve cover, hard to find because if I recall, it's hidden under the bracket for the coil packs.
A lot of times, the grommet that holds the line in the valve cover gets deformed from the heat it's subject to.
Old Jun 16, 2015 | 09:46 PM
khel72's Avatar
Thanks Maniac Iran out to the garage and found it. Not knowing how long that been sitting open should I just go ahead and change the oil out?
Old Jun 17, 2015 | 10:01 PM
I wouldn't worry about it. It's a small opening and shouldn't compromise your oil.
Old Jun 17, 2015 | 10:33 PM
khel72's Avatar
Thanks once again. Got the new part and the project continues.....
oaky812
Aug 7, 2024 03:49 PM
Slamjunk
Sep 29, 2014 03:56 PM
joemccall86
Jun 18, 2013 05:50 PM
polecat702
Dec 11, 2010 08:11 PM
roflcopter
Apr 9, 2009 02:23 AM
