6th Gen ('00-'05): Tail Lights and Dash Lights are Out
My Dash Lights and Tail Lights went out. Everything else works great where could I begin to figure this issue? Checked Alternator its good Battery Good. Is it possible to blown more than one fuse, for all this to go out at the same time?
I would start by checking the fuses. If one or more blew, it could be just "bad luck" or there is a problem, but it all starts with checking the fuses. then check wiring.
That is odd. Unfortunately, I am not sure what is shared or not shared with those circuits. This is probably going to require getting some wiring diagrams and tracing it out. I've heard a lot of new car dealers tend to share that data at no cost to people. May want to see if a local dealership can help you out.
4th Gen ('81-'88): No Headlights,No dash Lights,No Interior lights
Torn151
11-27-2016 05:10 PM
