Tail Lights and Dash Lights are Out
My Dash Lights and Tail Lights went out. Everything else works great where could I begin to figure this issue? Checked Alternator its good Battery Good. Is it possible to blown more than one fuse, for all this to go out at the same time?
I would start by checking the fuses. If one or more blew, it could be just "bad luck" or there is a problem, but it all starts with checking the fuses. then check wiring.
Checked fuses all,they all look good. Check Light functions Head Lights, Brake Lights, Signals, everything works but the driving rear lights and Dash Lights not working.
That is odd. Unfortunately, I am not sure what is shared or not shared with those circuits. This is probably going to require getting some wiring diagrams and tracing it out. I've heard a lot of new car dealers tend to share that data at no cost to people. May want to see if a local dealership can help you out.
Thanks
