No dash lights or taillights
Old Dec 14, 2018 | 04:46 PM
Mamba2424's Avatar
Default No dash lights or taillights
I have a 2003 monte carlo ss having problems with night time dashlights and taillights everytime it gets dark it blows 15 amp fuse for taillights in passenger side fuse box ,i have replaced head light switch and all bulbs in vehicle, any help would be appreciated!
Old Jan 14, 2019 | 06:39 PM
Skatulaki's Avatar
To the best of my knowledge, ALL cars are required to be built with the dash lights going out if your tail lights go out, so that you know you don't have tail lights. I have been a copy machine repairman for over 30 years, and I can tell you with almost absolute certainty that, somewhere in your tail light wiring you have a pinched wire somewhere, and when the lights come on your toasting the fuse. It also could be in the dash light circuitry. How quick you find it will depend on how good your memory is on whatever work was done to it right before you had the problem. Otherwise you will have to follow the wires and inspect them. Any place you took the car apart prior to having the problem is a likely spot. If you are any good with a wiring diagram and a multimeter, you can maybe shorten your time. You can get a multimeter Free sometimes at Harbor Freight, Set it for Ohms ( funny Horseshoe ) / Continuity, and you can start with the wires at the taillights that are suppossed to have 12v and see which is shorted to ground. If you need more detailed help let me know. Its possible that it could be shorting for some other reason, but most likely somewhere where some recent work was done.
Old Jan 14, 2019 | 07:15 PM
Mamba2424's Avatar
Thank you for the info, as of right now i do have tail lights i don't know how but i do i covered up sensor on dash so i do have my taillights but still no dash lights i have just been dealing with and with the weather like it is where i live and no garage i have just been dealing with it but what you said makes sense since i have replaced blower motor and fan speed control relay that is where i was going to start to look! Again Thanks
Old Jan 14, 2019 | 08:31 PM
Skatulaki's Avatar
Yeah, you prolly pinched a wire, don't feel bad, nothing any electrical repair person hasn't done a few times ! :-)
Brandon Johnson
May 22, 2019 12:15 PM
2001montecarlo
Mar 15, 2017 08:23 PM
dave countie jr
Feb 6, 2016 08:05 PM
8687mc
Feb 11, 2014 05:28 PM
espo83
Sep 12, 2008 10:00 PM
