no dash lights or running lights
Old Sep 11, 2008 | 10:02 PM
espo83's Avatar
Default no dash lights or running lights
hi i have a 2003 monte carlo ss 3800 about a week ago my dash lights went out along with door lights but the dome light and the floor lights work. a buddy of mine was following me one day at night and come to find out i dont have running lights/parking lights either so i checked all the fuses on both sides of the car with a multi meeter everything checked out ok i cant figure this problem out if anyone could give me some info that would be great oh yeah turn signals and brake lights work
Old Sep 12, 2008 | 06:04 PM
kweef's Avatar
Default RE: no dash lights or running lights
hmm possible coincidence? check to c if u have voltage to the fuses for the lights that are out...90% of the time an electrical problem in a circuit is the load so visually inspect the bulbs in the running lights to make sure they are not burnt out...i dont ahve time now but i will look on the wiring diagram and c if they intertwine anywhere
Old Sep 12, 2008 | 07:01 PM
mickey's Avatar
it is one of two things. mine did this same thing.
it is either the multi switch for your high beams or the actuall light switch.
After mine did the dash lights i changed them out to L.E.D. and never had another issue with those.
Old Sep 12, 2008 | 10:00 PM
RickCoMatic's Avatar
If the Fuses are all good ... you got +12V showing ... it could be a problem with the infamous "Bodywork Control Module".
rg9johns
Jan 2, 2022 05:51 PM
ctownbandit
18
Oct 13, 2018 04:49 PM
rg9johns
Aug 22, 2014 10:46 PM
TKG2000
Nov 28, 2011 02:03 PM
01LS Goin Bad
Oct 28, 2011 12:48 AM
