Stumbling at Idle and deceleration on 04 SS
Old Nov 10, 2011 | 11:15 PM
Teacher's Avatar
Default Stumbling at Idle and deceleration on 04 SS
Hey all so the monte has had a weird stumble for awhile now. When sitting at a light or coasting the rpms will drop and the headlights and interior lights will dim, it then catches and the rpms rise and it does it again. It accelerates fine and is still getting good gas mileage. Do you think it might be the MAF? It has 130,000 on it with a wizaired cai.
Thanks in advance
Old Nov 11, 2011 | 12:11 AM
nitehawkjcb's Avatar
Could be a lot of different things...
Unplug the MAF and see if it still cuts off
Old Nov 11, 2011 | 05:49 AM
When is the last time plugs/wires have been changed? How many miles are on the current set...?
Old Nov 11, 2011 | 08:07 AM
You should pop out the IAC and give it a little cleaning
Old Nov 12, 2011 | 07:36 PM
Justin Knight's Avatar
If the lights dim it could be as simple as a bad battery connection. MAF may need cleaning, or the IAC like chibi said. Could even be a badly restricted fuel filter. And like mentioned spark plugs could be getting to their expiration point.
Old Nov 23, 2011 | 10:13 PM
Any solution to the stumble yet?
dscarchick
Aug 20, 2011 09:40 PM
Jamie
16
Jul 18, 2011 07:42 PM
2006MCSS
Sep 3, 2010 02:39 AM
HPNOTIQracing
Jul 1, 2010 08:59 PM
HPNOTIQracing
May 30, 2010 02:25 AM
