Strting Issues
Old Apr 15, 2015 | 08:49 PM
marshagup's Avatar
Default Strting Issues
I have a 2006 Monte Carlo with a 3.5L v6 engine. I started having trouble with this car this winter. I am female so my knowledge is very limited but I need to know enough to tell my repairman.
First the car started not starting like it should and I had the starter replaced. Then a few weeks later the battery was totally DEAD. When I put the key in the ignition to start the car nothing worked and I could not get the key to come out. I called the repair shop the next day and they told me that the battery was dead. They put a new battery in and it has been doing good. They put an Interstate battery in.
Today I had an errand to run and when I got ready to come home I put the key in the ignition and turned it and nothing. Lights came on. I turned it off and tried again and it started. I have started it about five time this afternoon to be sure it would start. It starts every time.
The car has 115,000 and has not had a tune up. That is my fault. I didn't realize you needed to have a tuneup after 30,000.
I have had the alternator tested at least five times and each time it test good. I have had this done at Auto Zone and at the repair shop. This shop has an A+ rating through the BBB.
The interior light and radio automatically shuts off after about two minutes so there is nothing that I have left on in the car. The headlights are auto.
My plan is to take it in for a tune up then take it to have a diagnostic to see what shows up.
I am female and don't know how to work on a car.
Any suggestions as to what might be wrong would be appreciated.
86montecarloooSS
Aug 16, 2006 03:50 PM
mayerichm
Mar 3, 2006 11:16 AM
jsteezy129
Nov 15, 2005 10:47 PM
jsteezy129
Nov 15, 2005 10:14 PM
GTown
Nov 11, 2005 11:27 PM
