Car stereo wont shut off with car/door opened
Old Apr 17, 2015 | 09:17 AM
r00t's Avatar
Default Car stereo wont shut off with car/door opened
Hello, i recently installed my new stereo and amp/sub. I didnt use a wiring kit fyi. i spliced the wires together and figured out which goes to which. When i shut down the car, my stereo doesnt shut off and my battery dies after a while after being shut off. Can someone please help me!!! Thanks!!
Monte Carlo SS 2002
Old Apr 17, 2015 | 09:41 AM
Wire the main power to a fuse that shuts off, or the accessory wire that is telling the stereo to shut off, you can also run that to a fuse that shuts off when the car is turned off.
Some of the cheaper harnesses do this for some reason and I never really cared enough to look into why it did it, I just ran off a fuse that gets their power cut when the key is turned to off. You can test this pretty easily, otherwise I can check after work to see which fuse I used as well.
Old Apr 17, 2015 | 09:43 AM
r00t's Avatar
word, thanks for the reply man! a couple people told me about hooking the blue wire thats coming from my aftermarket stereo (the remote wire?) to my ignition wire or ignition fuse.
and.i.crawl
Oct 29, 2013 10:21 AM
misfitmonte
May 9, 2011 12:24 PM
chamberz
Jan 17, 2011 09:30 AM
rob559
Feb 22, 2007 11:13 PM
thatyounginss
Oct 30, 2006 08:00 AM
