Starting Issue?
Old Dec 9, 2009 | 01:44 AM
lostcausenjtown's Avatar
Question Starting Issue?
Today when I started my car it started just fine. After letting it warm up, I made my usual 40 minute drive to work. Then, made my usual stop at the Racetrac. After leaving the store, I tried to crank up. The lights flickered(inside lights that is) and I heard a clicking noise. Eventually it started and I drove to work. After work, the same thing happened again. I don't know where to begin to chase this problem because it just happened about 12 hours ago. This is the first time that I have had such a problem. I am thinking it has something to do with the ignition switch because it only does it when I try to start my car. It is a 2000 Monte SS by the way. For the sake of being thorough, I broke a vacuum line this weekend. You can read about that in this thread https://montecarloforum.com/forum/sh...58&postcount=1. Could a vacuum line cause this to happen. Please help. Thanks in advance.
Old Dec 9, 2009 | 12:47 PM
Didn't think to check the battery. I will check that and report back.
Old Dec 9, 2009 | 05:16 PM
RocknSS04's Avatar
Sounds like your BCM is going bad. The lights flickering and the clicking noises (all at the same time), those are the signs. Things will get worse. Try to find a used one, or get one from gmpartsdirect.com. You can always order one from your dealer and dicker with them. I typically get about 20-25% off list price from the dealer on special order items (specials are pure profit). Wait until it dies and you won't get that deal.
Old Dec 14, 2009 | 07:22 PM
Yeah I kinda found that out like a day after I posted. I have been looking for a good one. Gonna replace it around Christmas if I can make it that far.
Old Dec 14, 2009 | 11:10 PM
so exactly what do you think the issue is a BCM or battery? please let us know, thanks
Old Dec 15, 2009 | 12:16 AM
Well my battery cable was a bit loose. I have since tightened it down and have had no problems cranking. However, I had a diagnostic check ran at the local chevy dealer and the results pointed towards the BCM. I should have thought about it a while ago. I have been having minor electrical "hiccups" since this time last year.
Old Dec 16, 2009 | 07:03 PM
monte07's Avatar
bcm? cant really think what that is just had a brain fart
Old Dec 17, 2009 | 02:38 AM
I think it stands for Body Control Module.
Shandley
Nov 6, 2010 03:48 PM
04MonteLS
Nov 14, 2009 04:58 PM
01montesf
Sep 2, 2009 05:26 PM
monte carlo 3831
Jun 2, 2009 05:58 PM
