Auto Tips ?
Old Sep 10, 2010 | 11:54 AM
Thumbs up Auto Tips ?
Just received my newsletter from Valvoline that
has some good infor for novice mechanic's like me : )
Hope it helps a `Member
"Share, cause U care"
Is Your Car Ready for School?
If your vehicle is headed back to campus or the carpool lane, make sure it's prepared for school. A good maintenance check will give you peace of mind and a passing grade before you even hit the books.
Auto Advice That's Not Just AcademicTake some time to go back to the school of car care. If you or your kids will be driving to school this fall, become educated in regularly maintaining your car. You may even learn something.Read More
Wheel and Tire Clean UpWheel and tire care has come a long way over the years. Make sure you're up to date on the latest products and tools to keep things sparkling.Read More
Refuse to be a VictimYou have the power to avoid virtually every auto accident. Start by refusing to be a victim. Here's how.Read More Also This MonthTricks to Buying a Used Car Part I
Tricks to Buying a Used Car Part II
Brake Fluid
Troubleshooting By Smell
Speedometer Replacement
How Steering Works
Old Sep 10, 2010 | 02:15 PM
Sparky-88's Avatar
Thanks for the link to the Valvoline site, KidSpace! Some good info there.
Old Sep 10, 2010 | 02:20 PM
...Thanks `Dave, it's great to read that my investment of time/life is appreciated 4-Sure....I like their site & they give some great advise that I can even understand & apply : )
Great 2 see you online...Wish you & readers a Happy Eve & Super WeekEnd...~>EnJoy
Old Sep 11, 2010 | 06:26 AM
Power Train
  • Shifty Business A quick way to improve your car's acceleration without modifying your engine is to add a shift kit to your automatic transmission. This upgrade makes for a crisper, more precise response when... Read More
  • Changing Your Speedo Gear Improving the overall performance of your favorite ride by changing rear-end gears is common, but it's not the only gear change required. Inside the tail housing of your manual or automatic... Read More
  • Swapping Rear-End Gears In early September 1964, a southern Californian who loved the styling of the new 1965 GTO checked all the right boxes on the dealer order form except one: the rear gearing. This musclecar was... Read More
  • Upgrading Torque Converters If your vehicle is pre-'90s and has an automatic transmission, chances are it could really benefit from a modern performance torque converter. In its quest for more efficiency and performance, the... Read More
  • Transmission Coolers The cooler your automatic transmission runs, the longer it'll last. Car manufacturers know this. To dissipate heat from the automatic transmission fluid (ATF), they route transmission lines through a... Read More
  • Shift Enhancements for Your Automatic The term "slushbox" was coined to describe the less-than-optimum shift characteristics of factory automatic transmission. All major manufacturers between the '50s and '70s offered mushy-shifting two-... Read More
  • Performance Torque Converter Install Many car enthusiasts believe that the path to better performance is through engine modifications. The problem is that engine modifications often don't work out exactly as you hope. Modifying a daily... Read More
  • Hydraulic Hybrid System The Environmental Protection Agency is testing a cheaper, simpler hybrid technology it hopes can greatly increase the mpg of American vehicles. The agency has 20 patents on the system and has already... Read More
  • Drivetrains Explained Just about every vehicular drive system imaginable is currently in production—each touted by its manufacturer as the obviously superior choice for you. With conflicting claims and confusing... Read More
  • Replacing Axle Seals As much as you try to ignore it, that pesky spot of oil on the driveway isn't getting any smaller. Sure, you can put a tray of some sort under the car, use cat litter, or some type of space age... Read More
  • Torque Converters and Fluid Dynamics While not at all new technology, the automatic transmission is the stuff of miracles. Step on the gas and engine energy is converted into forward motion, just like that. No clutch. No fuss. ... Read More
  • Working the Swing Shift Is that manual transmission in your front-engine/rear-drive import requiring a lot more movement than you care to expend in order to select a gear? For instance, are you ramming your fist into the... Read More
  • U-Joint Replacement If you're lucky enough to have the rear set or all of the wheels providing the motion to get your vehicle going then you may already know about u-joints. The u in u-joint stands for universal.... Read More
  • What's the Difference? It's time to face facts. Every once in a while your rear end needs a little help. Whether you drive a rear-, front-, or all-wheel-drive vehicle the wheels spin by way of a differential. The gears... Read More
  • Precision Sport Shifter Install To the driving enthusiast, there's simply nothing better than rowing through the gears on a standard transmission. Whether it's a heel-and-toe downshift into a corner or an up-shift after the apex,... Read More
  • Automatic Reaction Like the human body, your vehicle runs on fluids: gas, engine oil, lubricants and the lesser-known transmission fluid. Without a sufficient supply of all the above, your vehicle can come to a... Read More
  • Auto-Trans Rear Seal Replacement Automatic transmissions are one of the least self-serviceable components on a vehicle. The complexity of these transmission's internal parts requires specialized knowledge to rebuild them. However, a... Read More
  • Behold Your Timing Belt Mechanics sometimes refer to the camshaft as the brain of your engine because it keeps all those pumping valvetrain parts working together so the air/fuel mixture enters and exits the cylinders on... Read More
Aug 20, 2013 10:32 AM
Jul 9, 2010 06:52 AM
Apr 17, 2010 05:09 AM
Aug 8, 2009 05:05 AM
Jul 6, 2008 11:36 AM
