service tire monitor system....
Old Mar 15, 2012 | 02:08 PM
joeykl66's Avatar
Default service tire monitor system....
i put air in my tires and hit relearn button on accident now i have low pressure lites on and service tire monitering system lights on. how do i reset my comp. to turn these off? ty,joe
Old Mar 15, 2012 | 02:20 PM
You have to go through the whole relearn process now.
Put the car into relearn mode, and now you have to either remove air, or add air in the driver's front tire until the horn honks, then move to the passenger front until it honks, then passenger rear, then driver's rear. When all 4 honk you have successfully did the relearn process.
Then you have to set all the PSI to the recommended 30/32 that the door jam says.
This procedure is also listed in your owner's manual
Old Mar 15, 2012 | 02:22 PM
joeykl66's Avatar
i thank you sir!!!
Old Mar 15, 2012 | 02:24 PM
Originally Posted by joeykl66
i thank you sir!!!
Every time you rotate your tires you should do this also, so the car can tell you the correct tire.
Old Mar 15, 2012 | 03:21 PM
joeykl66's Avatar
nice and easy! thank you again it worked!!!!
Old Mar 15, 2012 | 03:32 PM
Glad to hear you got it
Old Mar 15, 2012 | 04:46 PM
joeykl66's Avatar
thanks again!
montejass
FWD Tech Guides '95-'07
42
Sep 22, 2021 10:19 AM
Brinksta
May 2, 2015 08:13 PM
3900Hero
Oct 26, 2011 10:08 AM
01montesf
Oct 8, 2009 07:40 PM
Great White North
May 10, 2007 10:58 PM
