No headlights this morn
Old Jan 13, 2015 | 07:18 PM
ronipooh's Avatar
Im about to replace mine for the fourth freaking time in 2 years. Some days I want to blow this car up!
Old Jan 14, 2015 | 05:24 AM
avendo's Avatar
Yep i feel like i made a mistake buying this car too... The ride is horrible at 14 deg.. That fe4 suspension is harsh... And the struts i got for rear feel like they sank on height too.
Old Jan 23, 2015 | 12:22 AM
I just had the same problem that you were having with putting the steering wheel up and the lights not working. It turned out there were wires touching on the back of the multi function switch. I moved then around and now it is fine.
Old Jan 23, 2015 | 04:34 AM
avendo's Avatar
Where were the wires.. Under the plastic cover?
Old Jun 3, 2018 | 05:42 PM
SCHMIDTY's Avatar
Did you change out the dash switch assembly or the multifunction switch on the collum to fix your problem? I am thinking about just wiring the power up to the fog lights until I can figure out if it is the multifunction switch or the dash switch assembly.
Thanx SCHMIDTY
Myshell Ray
Mar 22, 2017 12:51 PM
Monroe
Apr 28, 2015 03:05 PM
02ssLE
Sep 5, 2011 06:08 PM
02ssLE
Aug 12, 2011 11:53 AM
Jster
Jan 11, 2008 05:30 PM
