No headlights this morn
Old Dec 15, 2014 | 05:25 AM
avendo's Avatar
Default No headlights this morn
Weird one I start car and no driving lights or headlights,got high beams and fogs..pull light switch and still nothing..possible for both lights burnt out at same time...lol,i guess i will check it out when i get home after work...
Old Dec 15, 2014 | 03:30 PM
avendo's Avatar
when I tilt the wheel up the lights go on,i replaced the radio buttons the other day..took airbag off,is there anything in there or is it a plug under the column that's loose? help.
Old Dec 17, 2014 | 12:05 PM
Sounds like a bad connection/pinched/loose wire.
Id take it apart and recheck all the connections/broken wire.
Old Dec 18, 2014 | 05:14 AM
avendo's Avatar
Whats under there that can screw up..i have had no problem now.
Old Dec 18, 2014 | 06:31 AM
I thought in a past post you mentioned you had the steering column apart?
If not...
It could be your multifunction switch/turn signal high beam control is failing?
also you could check the connection where it plugs in at the bottom of the steering wheel.
Old Dec 18, 2014 | 11:28 PM
babyjokerxxxxx's Avatar
i agree with STUMPMI and the multifunction switch(which i just changed) might be going bad. sounds like the same problem i had minus the tilting of the steering wheel.
Old Dec 18, 2014 | 11:32 PM
just in case it is the switch i just got mine on ebay for 38 dollars from this seller acautoparts04....was the cheapest i could find and a direct replacement.
Old Dec 19, 2014 | 04:24 AM
avendo's Avatar
is it easy to change?..it has been fine since it came back on...
Old Dec 19, 2014 | 04:55 AM
owens91's Avatar
Took me an her to change I say is fairly easy
Old Dec 19, 2014 | 05:48 AM
avendo's Avatar
there must be a youtube on it someplace...
