6th Gen ('00-'05): Need help.
Old May 15, 2024 | 04:49 PM
Maximus08's Avatar
Default Need help. Replaced timing kit car won't start
I bought a new timing kit. Installed it. Hooked everything back up like youre supposed to do. Now once I do the passlock bybass with the 10 min intervals the security light goes off but it still wont start. It's throwing ignition codes but I don't see having to replace anything bc it wasn't messed up before I started. Any advice would be much appreciated
Last edited by Maximus08; May 15, 2024 at 04:56 PM. Reason: More detailed in title
Old May 16, 2024 | 08:33 PM
Sorry, I'm not following this at all.
You bought and installed a timing kit - like the chain + sprockets? Did the original break?
Has it ever run OK? You mention doing some kind of security bypass, but just unplugging the battery to change the chain shouldn't have done anything to the security setup so I'm wondering why you have to bypass anything.
Edit- also what car / engine is this on? I presume its a 95+ since you mention a security module.
Old Oct 28, 2024 | 01:55 PM
Maximus08's Avatar
2004 3.8L
sprocket was cracked.I bought the timing kit. new sprockets top and bottom and a new chain. I also had to get a crank sensor which is where this all started from. When I put the harmonic balancer back on from changing crank sensor i didn't line the keyway up. (first time taking off balancer didnt know you had too) and when i tried to start it. timing chain sprocket cracked. I had bought the timing kit. I got it in time got the crank sensor on ever since then its been in antitheft mode
03Montepacecar
Sep 30, 2025 12:45 AM
03.MonteCarloSS
Jul 13, 2016 10:46 PM
MG426
Sep 20, 2015 08:02 AM
ohara
May 12, 2014 04:25 PM
ErMiller79
Oct 19, 2012 05:17 PM
