Monte Carlo Radio Issues
Old Oct 20, 2011 | 07:48 AM
Brugert's Avatar
Thanks Mistress!!!
Old Oct 20, 2011 | 10:06 AM
Originally Posted by Slugger088
Did the 2006 mc SS come with an amp? I still am not sure what stereo system my car came with. I have the 5 disc changer with a grey box in the trunk.
No problem Brugert! I'm assuming that took care of your problem?
Slugger088, the factory amp is in the trunk, mounted up under the rear shelf. I'm aware of three systems for the 06 Monte: base radio with single CD, MP3 radio with single CD (standard in SS), and MP3 radio with 6-disc CD (option in SS). I'm pretty sure your 5-disc CD changer in the trunk is not factory. Unless I'm unaware of something, I've never seen, nor am I aware of, GM mounting a factory CD changer in the trunk on these cars. I'd say you probably have the MP3 radio single CD system and someone added the 5-disc changer as an aftermarket addition? I could be wrong. Anyone else know more?
Old Oct 20, 2011 | 09:38 PM
mrittenhouse's Avatar
Would disconnecting the negative on the battery not do the same as pulling the fuse? I'm just asking because of my mystery problem I'm having in my front DS speaker. It crackles and pops at random while driving and will sometimes continue to do this when I turn the car off and close the door (even when the dome light goes out). Changed the front speakers out today (they're old anyway) thinking it was a ground problem in that speaker but it's still doing it.....
Old Oct 24, 2011 | 08:16 AM
Slugger088's Avatar
Monte of the Month -- August 2013
Hi 06mistress,
Well there is indeed something mounted up under the rear shellf of my car. I am 100 % positive my disc changer is a 5 disc changer with an AUX to plug an iPOD in for mp3's. I load all my discs in the actual unit itself not in the trunk or anything like that. My system looks exactly like the units that come in all of these cars so I know its not an after market stereo.
I will take a picture of the amp I have and maybe someone can tell me if what exactly I have in my car. All i can read off the amp itself is a sticker that looks to say panasonic. I will post pics in the next couple days.
Thanks
Old Oct 24, 2011 | 08:49 AM
I misread what you initially said. I thought you meant the CD changer WAS the gray box in the trunk... I gotcha now. I did check my factory amp, in the trunk, and it IS a Panasonic. The factory unit in the dash should be a 6-disc changer though, but yeah post a few pics when you get a chance!
Old Nov 15, 2011 | 08:32 PM
Brugert's Avatar
Well actually I can't get that little radio fuze out, and I don't want to pull on it so hard as to break it. What do I do? -_-
Just Call Me Monte
Sep 16, 2014 10:59 AM
MRagland828
Apr 2, 2011 01:31 PM
ralphtrent
FWD Tech Guides '95-'07
Nov 28, 2010 04:35 AM
labnjab
Aug 17, 2010 12:49 PM
pcwb
Dec 13, 2008 06:35 PM
