Engine Heat
Old Nov 5, 2011 | 10:03 AM
eastnjman's Avatar
Arrow Engine Heat
When i drive my car i feel heat coming threw the vents, that i know is normal.Butt should it be so hot that i never have to turn the heat on.Does any 1 elses cars do this;and if so how do I fix it?
Old Nov 5, 2011 | 10:04 AM
if you have the temperature sent to heat but the fan at 0 the speed of the air moving over the car as you drive will push air through the vent system. I tend to not use the fan when at highway speeds as the air being pushed through is usually enough. Maybe thats what you're experiencing?
Old Nov 5, 2011 | 10:38 AM
Driving at highway speeds pushes enough air through to move it into the cabin and transfer the engine's heat. I had been doing a lot of highway driving up til this past spring. I usually have the blower set to the floor and the fan off most of the time, and would still have air movement sometimes. I do remember it being pretty warm once and a while.
Old Nov 12, 2011 | 10:05 AM
eastnjman's Avatar
Thanx guys these tips really heleped
Old Nov 14, 2011 | 08:41 AM
I usually drop it to halfway when I drive without heat on. Because it really does stay warm lol
Old Nov 15, 2011 | 10:07 PM
Justin Knight's Avatar
If you push the recirculate button then turn the blower off it should stop almost all the air flow but it needs the be on the dash for the HVAC control to allow it to happen.
04chevyboy
Dec 16, 2011 12:39 PM
red04montels
19
Sep 30, 2009 08:33 AM
Kruelty
Nov 12, 2007 07:43 AM
omb76
Aug 15, 2007 07:23 PM
skimmy
Jan 13, 2007 02:14 AM
