85 Monte Carlo 355 CI recommendations for manual tranny swap
Old Aug 5, 2013 | 09:26 AM
Jimmy Criswell's Avatar
Default 85 Monte Carlo 355 CI recommendations for manual tranny swap
Hello everyone,
I have a mildly modified .030 350 with iron eagle heads. Comp cam 456 lift 261 duration (close to those numbers...don't have cam card in front of me now). Block has been align honed and rotating assembly is eagle balanced. About 9.2:1. I have the TH 200R and know I will have to baby it until transmission is replaced.
Does anyone have any recommendations on bolt on 5 speed or anything manual that has an overdrive so I don't have to change my rear gears. I am looking for minimal cost if possible. Block is 79 left dip 4 bolt main. Thanks!
Old Aug 5, 2013 | 10:28 AM
Budsjlm's Avatar
I would just go for the lt t56 6speed or get a t5
Old Aug 5, 2013 | 10:32 AM
both will bolt up directly to an old small block Chevy?
Old Aug 6, 2013 | 02:44 PM
seen03's Avatar
Also vote for LT/LS Fbody T56.
If you're familiar with manual transmissions and their parts, it wont be overwhelmingly difficult.
If I recall...there are a few companies out there that sell a complete conversion kit...from the clutch pedal, slave, to clutch n trans.
85ssmonte355
Mar 19, 2015 08:00 PM
ryansss
Aug 25, 2012 10:20 AM
archfiend
Aug 17, 2010 10:33 PM
350_SS
Jul 20, 2009 11:41 AM
countryboy07
37
Dec 18, 2007 09:18 AM
