Strange loud popping sound
Old Jan 15, 2014 | 11:34 AM
iMuf's Avatar
Default Strange loud popping sound
So over the last week or so this has happened a couple times. I will turn my car on and I will get a loud popping sound that I think is coming from the air conditioner vents. If I shut the car off and turn it back on it will go away or if I drive around for a minute it will go away. Anyone have an idea of what that might be. I will keep my camera with me and see if I can get a video of it next time it does it.
Old Jan 15, 2014 | 12:26 PM
vikesfan's Avatar
turn the air off in the car and restart to see if it still makes the sounds.
if not, then my guess is that you have some debris in the blower motor
Old Jan 15, 2014 | 09:01 PM
iMuf's Avatar
Yea it does stop. If I start the car and it does it, then I just turn the car off and wait a sec. Then I start it back up and it is fine again.
Old Jan 15, 2014 | 09:07 PM
djhixter's Avatar
sounds like it could be a blend door motor or vent motor actuator...many gms will actually make continuing popping noises while the engine is running...if i do remember correctly, there is a recalibration procedure that you can do if this is your problem...i just can't remember what the procedure is...may want to check online to see if you may be able to find the calibration sequence, again, if this is the problem...hope this helps
Mr Grizzly Mint
Jan 24, 2012 02:06 PM
nighthawk626
Oct 18, 2010 09:48 PM
rgant_19
Jul 20, 2009 02:19 AM
Willis_454
Mar 11, 2009 01:51 PM
thewhitestcarlouknow
Oct 16, 2007 09:49 PM
