FAQ: Jacking up the car help
Old Apr 15, 2020 | 07:46 AM
17bran40's Avatar
Default Jacking up the car help
Where are the jack points for the 2004?
When I try to jack it up on what appears to be where I need, the fender starts shifting. So im probably doing this wrong. Picture would be a great help! Still new to this stuff
Old Apr 15, 2020 | 08:46 AM
Old Apr 15, 2020 | 09:21 AM
17bran40's Avatar
Thank you!
Old Apr 16, 2020 | 11:56 AM
Personally, unless I am using a scissor jack with a saddle to hold on the pinch weld, I prefer NOT to use that as a jacking point. And if your car is getting rusty (like many of these do), I prefer that spot even less. And the unibody frame can become questionable as well.
If you are using a floor jack, I would use the the front subframe (aka, engine cradle) or for the rear, center of the rear suspension cradle. Use jack stands on the unibody frame or subframe or rear cradle. If I am taking a wheel off, I like to toss it under the rocker panel, don't rest the car on it. That wheel goes there as an extra step incase my jacks fail.
zapp59
Mar 15, 2013 07:10 PM
Franks 03SS
Jun 1, 2012 08:10 AM
Franks 03SS
Feb 22, 2012 09:20 PM
slow rider
Aug 31, 2011 03:57 PM
USMC8825
Mar 16, 2011 05:33 PM
