Help: ABS, Trac off, BRAKE, and STS lights
Old Jun 1, 2012 | 07:33 AM
Franks 03SS's Avatar
2011 Monte Of The Year
Default Help: ABS, Trac off, BRAKE, and STS lights
So A few days ago all these lights come
When I removed my rear struts I remember unplugging the rear hub sensors because of the wires being my way, when I was done I forgot to reconnect one of the plugs lol. So I turned the car on and the ABS and BRAKE lights came on. I simply connected the plug back in and the lights dissapeared, and now this happens. Could it be the rear hubs going bad and causing all these 4 lights to come on? Because when I had it unplugged only 2 of the lights were on or is it one of my fronts? I replaced both of em a few months back so I don't think they're it. I'm probably going to go ahead and replace both of my rear ones anyway lol
What do you guys think? Could it be something else?
Old Jun 1, 2012 | 07:48 AM
Check your brake fluid for the BRAKE light.
When you had the sensors disconnected, perhaps they got dirty? Try cleaning it and putting it back together.
Old Jun 1, 2012 | 08:10 AM
i'll check the fluid later, but the BRAKE light only comes on when the ABS light comes on.
my lowering springs are suppose to get here later so i'll check everything when im taking the struts out and stuff...
Thanks for your response mike
matthew41
Jan 25, 2015 11:22 AM
cbcain1978
Jun 19, 2013 03:47 AM
Jerry Barao
Jan 12, 2013 07:54 AM
Jokers1995
Jul 31, 2012 09:11 AM
