Jack up points
Old Nov 9, 2012 | 05:16 PM
Lorenzo's Avatar
Default Jack up points
Hey guys i need to jack up the car tomorrow to put the new wheel stud in and im confused on where to jack it up. I know usually your supposed to do it on the pinch welds but mine are rusted alot and i dont feel safe putting it on there. I need a place to jack it up and place a jack stand underneath. Its for the front of the car but i would like to know for the back too for the future. Im too used to my 86 Monte that had a full frame and places that i knew where safe to jack up in the front and back :p
Old Nov 9, 2012 | 05:30 PM
Old Nov 9, 2012 | 05:35 PM
Lorenzo's Avatar
ive seen this picture a couple of times but im confused a bit. Like where can i jack it up in the front to get both wheels off and when i place the jack stands underneath do i put them on the control arms? If so where on them? Thanks
Old Nov 12, 2012 | 09:01 AM
In the above left picture, put your jack under number 1 and jack up the car. That will lift both front tires at once. Then you put the jackstands on the 3 point.
For the rear, you put the jack on number 6 and jack up both rear tires at once. Then put the jackstands on number 4
The rear jack point is near the exhaust Y pipe, be careful not to crush that
Old Nov 12, 2012 | 07:40 PM
Lorenzo's Avatar
Ok what is number 1 though? Whats it called? The 3 point is that the pinch welds or the control arms? And what does the rear jack point look like?
Old Nov 13, 2012 | 07:30 AM
1 is the cradle of the car.
6 is a very solid piece of the frame right near the exhaust.
3 could be the pinch welds, but mine aren't in great shape either, you should see the frame running down the sides as well and you can safely put jackstands tehre.
Shandley
Jul 28, 2010 10:55 AM
mavrickf1613
Jun 2, 2008 04:47 PM
mavrickf1613
May 24, 2008 02:33 AM
sickofsoyo
Dec 27, 2007 12:18 AM
blie
May 30, 2007 06:57 PM
