ignition?
Old Nov 9, 2007 | 04:11 PM
blazerman3's Avatar
Default ignition?
Nothing to do with our beloved montes but..........neighbor has a `95 blazer. Shut off while driving and will not restart. Cranks good but does not fire. I`m thinking the ignition module. Any ideas??? Thx...4.3 liter with EDI ignition?
Old Nov 9, 2007 | 05:35 PM
1977Monte's Avatar
Default RE: ignition?
You need to check for fuel pressure and check for spark at the plugs when it starts acting up. Simple enough to check spark just pull off a boot and see if it will arc out to a ground when cranking.. fuel pressure you need a gauge to accurately check.. aren't very expensive. should be able to pick one up anywhere.
Old Nov 11, 2007 | 03:06 PM
04 Intimidator's Avatar
It could be a Passlock security issue, but that would be reaching for it. If it is you will not hear the fuel pump kick in. Might want to goto a junk yard and just pull a new ignition and key to test with.
trigger
Jun 12, 2006 04:05 AM
soldout162000
Mar 24, 2006 12:34 AM
john123
May 29, 2005 02:57 AM
Cobramen
May 25, 2005 01:06 PM
big green dog
Apr 30, 2005 10:24 PM
