hei ignition
Old May 26, 2005 | 12:01 AM
john123's Avatar
Default hei ignition
Hi i was wondering if someone could tell me how to wire up a 1976 vacum advance distributor in my 1986 monte carlo ss, like what parts i need , what type of wiring, whatever i might need to know, thanks
Old May 26, 2005 | 03:45 AM
04MonteLS's Avatar
Default RE: hei ignition
I don't know why im responding cause I don't have a clue. Good luck though!
Old May 26, 2005 | 01:04 PM
montejass's Avatar
Your responding cause your a POST *****......... lol Boost would be the best IMO to cover this one.
TVW
Old May 27, 2005 | 02:53 AM
Boost's Avatar
You are installing an HEI Distributor????
Well just connect the red power wire to the right side of the cap and the Brown Tach Wire to the left side of the cap. The Red power wire is on a connector with a white wire, i believe, just cut the red wire off and use a female connector to connect it to the distributor. There is no need for the white wire... Use manifold vacuum for the vacuum advance, and make sure your on top dead center. I can get pics of what you need to do if you get stuck...
Old May 27, 2005 | 03:36 AM
04MonteLS's Avatar
ORIGINAL: tvanwinklehome
TVW
How do you figure that?
Old May 29, 2005 | 02:57 AM
john123's Avatar
sure, ill take some pics, if u want u can email me at johnierotten@pennswoods.net, thanks
soldout162000
Mar 24, 2006 12:34 AM
Cobramen
May 25, 2005 01:06 PM
big green dog
Apr 30, 2005 10:24 PM
