7th Gen ('06-'07): HVAC climate control issue
Old Jan 15, 2022 | 06:37 PM
Drock1's Avatar
Default HVAC climate control issue
The climate control for the driver side won’t work. Any tips or do I need to replace the whole control panel? Thanks.
Old Jan 16, 2022 | 08:08 PM
Define "does not work at all". Does air blow out of it? Is it hot or cold?
As for what it could be:
- Bad Hvac control panel
- Damaged wire
- Defective HVAC module actuator (usually it makes a clicking noise when you adjust the temp)
In my 2004 Monte, the driver side never really blew cold air. I had to rip the dash out and pull the HVAC module in order to replace the evap core for my AC at one point. During that, I found an issue with the flappers that control the dual climate AC. The one did not move well because the hinge point for it was too stiff. I used sand paper to worked down the one post just a couple hairs. Put it back together and all is great!
Old Jan 16, 2022 | 08:54 PM
Drock1's Avatar
When I slide the **** from cold air to warm air it stays cool.
mkenney
Nov 8, 2021 04:22 PM
Onion39
Jul 27, 2018 02:39 PM
Rodney Smith
Sep 17, 2015 05:02 PM
robknight13607
Jan 4, 2013 05:26 PM
jackjeckel757
Apr 11, 2011 07:26 PM
