Hub bolts
Old Nov 11, 2011 | 10:26 PM
bobj49f2's Avatar
Default Hub bolts
I am working on my wife's 1996 Monte Carlo. I am replacing the hub bearings and had trouble getting the four mounting bolts out of each bearing. They were stubborn but I got 6 of them out, two broke of in the old hub. Does anyone know the size or part number of the bolts? I want to replace all 8. I am assuming they're metric but there are different metric bolts with different threads. Also, I'm going to a parts store to buy them and a number would help.
Thanks,
Bob
Old Nov 17, 2011 | 05:23 PM
basicdumbass's Avatar
go to napa ,Im sure they have them.
Brian
Old Nov 17, 2011 | 07:26 PM
04chevyboy's Avatar
better off orgering them from gm.broke one a month or soo again.i went to 8 auto stores that didnt have them for my 04 monte which is probaly the same bolt.local car dealership had one from a monte laying around and gave it to me for free
Old Nov 18, 2011 | 09:04 AM
bobj49f2's Avatar
I ended up going to my local hardware store to buy them. I went to NAPA, they didn't have them. I then went to the Chevy dealer, the counter guy told me he and them but turned out they didn't but he gave me the specs. I went to the hardware store and got hardened bolts and steal spacer collars to copy the factory oringinals. Dealer price, he said he could order them, was $6.50 apiece. The hardware store was about $3 apiece, the most expensive part was the collar for $2+ apiece.
This car is turning into a money pit. Every time I fix one part it leads to another parts. The latest is the back brakes. I went to bleed the rears, one bleeder valve rounded off, the other broke off. I used a six point socket to try to free them up because I knew they were going to be a rust tight. Now off to the store for two wheel cylinders.
Old Nov 18, 2011 | 09:08 AM
bobj49f2's Avatar
Just for future reference, in case some one searches this forum looking for these bolts:
GM Part#10104548
Dim=10
Pitch=1.5
Length=43.2
Old Jul 28, 2022 | 01:02 PM
OLDBUICK89's Avatar
Default Looking for the collar
I am looking for the collar. Do you know the specs? I got the bolts at the hardware store too but he didn’t have the collar spacers. This isn’t available by Gm and it’s discontinued. I gotta do my wheel bearing on the drivers side and need these bolts.
Old Jul 29, 2022 | 08:55 PM
This is a thread that is over 10 years old. Many members have moved on to other platforms. It is best to start a new thread.
If this is on a FWD Monte, I have done many front wheel hub assemblies and I am not sure what spacer you are mentioning. I know there is a bracket to hold the ABS wheel speed sensor connection.
ChibiBlackSheep
FWD Tech Guides '95-'07
54
Oct 13, 2015 10:47 AM
work
Jul 30, 2014 09:22 AM
Radagast the White
Sep 15, 2013 03:00 PM
silverodo12345
Mar 19, 2013 08:34 PM
kc2kth
Aug 2, 2011 05:48 PM
