6th Gen ('00-'05): Front Cig lighter no longer working
Old Jul 20, 2022 | 09:15 PM
Zafira's Avatar
Default Front Cig lighter no longer working
My front Cig lighter no longer works, but my back one does. I checked the fuse on the drivers side for it and it's not blown. I just checked the fuses on the passenger side just to be safe and they aren't blown. It was working before and then stopped in the middle of use, before I just replace the cig lighter, is there another issue that could be causing one to work and not the other? It's only used to charge my phone.
Old Jul 21, 2022 | 09:25 AM
If the fuse is good, but the lighter isnt working, I'd pull apart the trim in that area and start looking at the wiring. Maybe a wire got disconnected from the back of the plug or maybe the ground wire doesn't have good connection.
Use a multimeter to figure out which side isn't connected all the way to speed the investigation.
Old Aug 2, 2022 | 03:19 PM
Zafira's Avatar
I ended up replacing the wiring. Thank you! It's on and working now
Kenny Guido Temprano
Oct 7, 2015 12:04 PM
elgato1013
Feb 6, 2012 08:26 PM
Jack The Ripper
Jan 14, 2012 04:40 PM
manny
Sep 23, 2007 02:11 PM
benhillzone3
Feb 23, 2007 01:42 PM
