Opinion Needed: Hit a curb on front passenger side
Can you provide more detail? Which stabilizer bar, front or rear? Is it the bushings for the end links? Is it the bushing holding it to the frame? What is the problem you are having?
Clues, he said FRONT passenger side, and stabilizer bar. Rear bar is a sway bar. But appears he disappeared.
Replaced sway bar link hub assembly after hitting a curb on front passenger side very hard to steer the steering wheel is a half turn to the left when trying to drive straight very loose steering and wondering and loud squealing. What should I check or look for should I have it aligned?
I'd check over the rack, tie rods, and rack mounting to see what is wrong. You probably broke or bent something.
That's a good point, I 100% agree!
I have heard people call front and rear sway and stabilizer bar. I read his comments vs his subject line (as his subject said front passenger and his comments made no mention). But thanks for the critique.
I don't often get a chance to correct you. Minor victory.
