Replacing front sway bar.
Old Feb 15, 2011 | 09:03 PM
orthokneepa's Avatar
Default Replacing front sway bar.
Has anyone on here replaced the front sway bar? I have before a couple times on my 96 camaro I used to have and it was no big deal. I was reading up on this swap out and read that I have to lower the frame? WTF really? Don't you just undo the endlinks, middle bushings, and replace? I just plan on using a stock replacement bar from GMPP.
Any tips, tricks, etc.
I have a 2000 Monte btw. Thanks
Old Feb 15, 2011 | 10:05 PM
Just from memory I think it goes over the engine cradle and there is not enough clearance to slide it out. Just my guess tho I'm not 100% sure.
Old Feb 16, 2011 | 06:24 PM
Thanks for the reply. I talked to my mechanic buddy and he said it can be done if you wiggle and work it through. Ill try it that way first.
Thanks
Old Feb 16, 2011 | 07:08 PM
kingreyna's Avatar
I did it myself just by wiggling it out. It's a little hard by oneself but some help should go faster.
ziggo_2
Feb 7, 2021 03:34 AM
Red Nightmare
Jul 13, 2013 12:17 AM
solaris_vii
Feb 17, 2013 05:12 PM
MONTE2000SS
Mar 8, 2012 08:05 AM
The_Maniac
Aug 31, 2010 07:58 AM
