Opinion Needed: Hit a curb on front passenger side
Old Jul 13, 2022 | 01:05 PM
jamiebeahan81@gmail.com's Avatar
Default Hit a curb on front passenger side
Having trouble replacing bushing for stabilizer bar
Old Jul 13, 2022 | 02:45 PM
Can you provide more detail? Which stabilizer bar, front or rear? Is it the bushings for the end links? Is it the bushing holding it to the frame? What is the problem you are having?
Old Jul 21, 2022 | 06:02 PM
GrayGhost1951's Avatar
Clues, he said FRONT passenger side, and stabilizer bar. Rear bar is a sway bar. But appears he disappeared.
Old Jul 22, 2022 | 03:18 AM
Default Please help
Replaced sway bar link hub assembly after hitting a curb on front passenger side very hard to steer the steering wheel is a half turn to the left when trying to drive straight very loose steering and wondering and loud squealing. What should I check or look for should I have it aligned?
Old Jul 22, 2022 | 11:47 AM
Its not ready for an alignment, something is still broken. The steering shouldn't be loose and squealing.
I'd check over the rack, tie rods, and rack mounting to see what is wrong. You probably broke or bent something.
I would say this is more than you can handle. Better to have someone diagnose it for you. Take to someone trusted and let them give you an estimate. If nothing else you will know what is wrong.
Old Jul 22, 2022 | 03:03 PM
Cant really help with your issue but I have to say.. If your steering is loose, binding, or doing anything strange, stop driving it for safety reasons. You or someone else could end up dead very easily.
Old Jul 22, 2022 | 04:50 PM
That's a good point, I 100% agree!
Old Jul 23, 2022 | 09:26 AM
I have heard people call front and rear sway and stabilizer bar. I read his comments vs his subject line (as his subject said front passenger and his comments made no mention). But thanks for the critique.
Old Jul 23, 2022 | 04:13 PM
I don't often get a chance to correct you. Minor victory.
wht02monte
Sep 24, 2021 02:40 PM
Drkoob
Mar 25, 2016 02:01 AM
owens91
Jul 10, 2013 05:55 PM
owens91
Jul 1, 2013 07:59 AM
orthokneepa
Feb 16, 2011 07:08 PM
