HELP!! headlight problems
Old Nov 27, 2014 | 06:45 PM
denningc20's Avatar
Default HELP!! headlight problems
So I have a 2002 with the 3.4 and my automatic headlights work when they want. Sometimes they'll turn on when I start the car and Sometimes they won't. When I'm driving they shut off and come back on at random. I've checked my fuses and relays but I can't figure it out. Maybe I missed something so will someone please help me.
Old Nov 27, 2014 | 07:08 PM
vincenti's Avatar
Is it just the automatic headlights (also known as daylight running lites) that turn off? Or does this also happen when the headlights are turned with the switch?
Old Nov 27, 2014 | 07:13 PM
denningc20's Avatar
It's just the headlights even when the switch is pulled out. My tail lights and side markers still work though
Old Nov 27, 2014 | 07:24 PM
vincenti's Avatar
Check around your headlights and make sure there aren't any exposed wires that are grounding out. If the wires there look good check you headlight switch. Sometimes those switches have a part in them that burn up. It's hard to see. It'll kinda look like scouring occured
ajsart
Dec 4, 2011 07:28 PM
redrat2000
Dec 16, 2010 07:15 AM
captaindamnit
Aug 12, 2009 10:26 PM
discomonty
Oct 25, 2008 01:05 PM
js2000mc
Mar 25, 2008 06:33 PM
