headlight help
Old Aug 5, 2009 | 03:14 PM
captaindamnit's Avatar
Default headlight help
I am needing to take out my passenger headlight to clean out some dust, and I was wondering how to take it off.
Old Aug 5, 2009 | 03:26 PM
What's your car?
The usual procedure is popping the hood and there are white clips on both sides of the headlight that you would pull out.
Old Aug 5, 2009 | 03:58 PM
jaws2008's Avatar
GOT SPL
^^^^^^^That way^^^^^^ and then the headlight almost falls out.
But yes what year if its and 00-05 i know that is how it works
Old Aug 5, 2009 | 05:22 PM
Pure2sin's Avatar
Pop the hood look to the left side of the left light there is a white plastic tab that is the top of the clip. Pull UP on the tab and the clip will come off. The right tab of the left light is under a little black plastic flap pull up and get your hand under that flap you will see/feel the second white plastic tab pull up on that one remove it and the light will be loose. Pull the whole headlight towards your body maybe with a little jiggle and it should come out. BE sure to disconnect the wire harness from the back.
Old Aug 5, 2009 | 09:59 PM
rgant_19's Avatar
Hey captaindamnit, make sure you don't drop the "white clips" that holds the headlights onto your monte down, in between the body of the front end. Its a b*%^$ trying to get it out.
Old Aug 12, 2009 | 10:26 PM
daves92camaro's Avatar
i always break mine
cstoots
Feb 19, 2012 09:55 AM
Emnasty600
Jul 8, 2011 07:17 PM
blackmonte781
May 7, 2011 05:40 PM
kclee6337
Jan 12, 2010 07:48 AM
discomonty
Oct 25, 2008 01:05 PM
