headlight problems
Old Dec 2, 2011 | 07:35 AM
ajsart's Avatar
Default headlight problems
I have a 2002 SS.
On the way home from work the tire pressure warning on the dash came on.
I stopped at a gas station and one tire was a little low but not enough to set it off. So I added a little air and figured a false alarm. The light stayed on. This morning the light was still on so I consulted the manual to see how to get rid of the light. It says with the ignition on pull the headlight **** out to the parking light position 3 times and the light will go out. It did.
So did my headlights. Now they won’t come on as DRL’s, automatically or manually. The parking lights come on as DRL’s. And the parking lights along with the tail lights come on automatically (or manually) but no headlights. The fog lights work, luckily. Weird. Any ideas? Thanks.
Old Dec 4, 2011 | 07:15 PM
ajsart's Avatar
Solved. For now. After sitting all day the DRL's or headlights still wouldn't come on. Just for the heck of it I jiggled the turn signal stalk and they came on. Then went back out. I did it again and they came on and stayed on. For whatever reason the headlight circuit, not just the brights, runs through there. Anyway, it's been working fine for a couple of days but it will have to be replaced.
Old Dec 4, 2011 | 07:28 PM
Yeah everything for lights is connected to it, deff needs to be replaced, glad u found the source of your problem
denningc20
Nov 27, 2014 07:24 PM
redrat2000
Dec 16, 2010 07:15 AM
js2000mc
Mar 25, 2008 06:33 PM
Magna131
Oct 27, 2005 04:36 AM
