Has anyone really ever fixed a P0440 evap code
Old Sep 29, 2014 | 12:28 AM
  #61
sams63ss's Avatar
Vent valve is on intake manifold gets broken occsionaly on intake gasket repairs I've replaced in 5 minutes a simple repair but check hoses for leaks first also at check dealer I smoke tested many times u can use tech 2 command purge valve increases while watching fuel tank pressure from ftps fuel tank pressure sensor readings if it falls off smoke test for leaks found various places necks. Tanks .lines .purge as well as vent valves needs to be checked by proffesional and sadly most techs don't have the knowledge even at gm shops
Old Sep 29, 2014 | 08:42 AM
  #62
gmjunkyard's Avatar
Old Oct 1, 2014 | 08:13 AM
  #63
owens91's Avatar
Yup I changed that and so far no evap code finger closed that it last until the 10th
Old Oct 3, 2014 | 07:45 AM
  #64
gmjunkyard's Avatar
Glad to hear it. Good luck.
aurgathor
May 24, 2013 06:30 PM
02montecarlo
Oct 11, 2011 03:06 PM
rockieg00
Mar 18, 2011 05:50 PM
scc24540
Jul 1, 2007 06:34 PM
yzf125
Jun 22, 2007 07:02 AM
