P0440 code
Old Jun 21, 2007 | 07:57 AM
yzf125's Avatar
Default P0440 code
I have had a check engine light on for some time now, So i had Auto Zone check it the other day and it says P0440 - Evap Emissions Control System Malfunction
Anyone get this code and have it resolved ?
I was going to start with buying a new gas cap and see if that works first, Any other suggestions ?
Old Jun 21, 2007 | 09:11 AM
Mrrench's Avatar
Default RE: P0440 code
I would check the cap to make sure that it is on tight
I would also check the chart under the hood and follow the vacuum hoses to make sure there are no leaks
Old Jun 21, 2007 | 09:24 AM
wiz kidd's Avatar
gas cap is most common, and its cheap to get another one, give'er a try
Old Jun 21, 2007 | 12:53 PM
yzf125's Avatar
I am going to buy a new cap today, If it is the problem and i have auto zone clear the check engine light, does it just turn of the light or does it clear the code ?
Reason i ask is i have a inspection coming up next month and i dont want it to fail because the code is still in there. ( Assuming it fixes the problem)
Old Jun 21, 2007 | 06:46 PM
yzf125's Avatar
Ok i put a new gas cap on , Do i have to have Auto Zone clear the code , Or will it go off on its own ? Thanks.
Old Jun 22, 2007 | 02:47 AM
Mrrench's Avatar
It should go out on its own
Old Jun 22, 2007 | 07:02 AM
wiz kidd's Avatar
if it doesnt go out then try clearing it, then if it come's back on then you know its something else
tridski
Oct 3, 2014 07:45 AM
02montecarlo
Oct 11, 2011 03:06 PM
Franks 03SS
Sep 21, 2011 05:15 AM
LilSeanCB
Jul 16, 2011 12:40 AM
rockieg00
Mar 18, 2011 05:50 PM
