Has anyone really ever fixed a P0440 evap code
Old Nov 14, 2012 | 07:22 AM
  #31
WannaMCSS's Avatar
Originally Posted by solaris_vii
you should give it a shot yourself first. all i had to do was crawl under the car, dont have to jack it up or take off a wheel or anything, look by the rear driver wheel and its right there held up by one 10mm bolt =)
you are right, and i really should have tried it myself 1st.
the mechanic i use is next door to my work so it's easy for me to let him do it, but i think even he was a little surprised that i didn't do it myself.
been a day and so far so good (knocking on wood)
Old Nov 14, 2012 | 08:08 AM
  #32
solaris_vii's Avatar
glad you got it fixed! seems to be a chevy problem lately. not only do i see it all the time on montes and impalas (i work at autozone and spend probably half my day reassuring people their check engine light does not mean their car is going to explode) but i just changed a vent valve on my dads z06. what the heck chevy! atleast source some good ones for your flagship car!
Old Nov 15, 2012 | 08:05 AM
  #33
ETexasTwister's Avatar
My 06 Silverado had the same problem. It has been reported that it is caused by overfilling your tank or filling it while the vehicle is running.
This causes the gas to be sucked in the Vent Valve. once it gets saturated your light comes on. That's why it comes and goes until it won't go off at all.
Old Nov 15, 2012 | 07:33 PM
  #34
this is interesting! ill have to make sure i dont overfill it anymore, i just like putting in all it can take one because i try to minimize gas trips and two because i like it to stay at full longer lol
Old Nov 16, 2012 | 06:25 PM
  #35
MillerMonteSS's Avatar
2010 Monte Of The Year
Did mine the other day! I'm not sure if it was the vent or the gas cap. I changed both. Good to go!
Old Nov 16, 2012 | 06:53 PM
  #36
aussiek2000's Avatar
Nope, they are just junk. C/K bodies, and w-bodies have a pretty high failure rate. Usual code I see is P0449 or P0455
Old Nov 17, 2012 | 09:48 AM
  #37
WannaMCSS's Avatar
Does a bad Vent valve affect gas mileage or performance in anyways?
Old Nov 20, 2012 | 05:25 PM
  #38
monte06ltz's Avatar
Originally Posted by tridski
I finally got the vent valve on order. Now where is it on the gas tank. Am I going to have to drop the tank or can it be done without dropping it. Has anyone ever changed one. Once I get it in my hands I should be able to find it on the tank, just by comparing parts. Thanks for any help. Dave
I have the same problem with mine and i have a 06 and i was told i had to drop the tank so you are probley going to have to do the same sorry
Old Nov 20, 2012 | 07:35 PM
  #39
You DO NOT have to drop the tank for the valve on your '06. Just look up from under the rear of your car near your fill tube and you will see it. It takes one 10mm bolt and a spring clamp. VERY easy.
Old Nov 21, 2012 | 07:12 AM
  #40
^^ this. you dont even have to take the wheel off, super easy!
