Grinding, No start and backpressure through the intake
Old Apr 14, 2021 | 04:42 PM
Ididitfordale's Avatar
Default Grinding, No start and backpressure through the intake
Hello everyone. I've been working on cars for a minute and have myself pretty stumped. I'm a "driveway certified mechanic" but am totally in over my head with this one.
About the car first, its an 02 monte carlo ss 3.8L naturally aspirated. I have an empty upper intake manifold, exhaust work, a pcm tune (zzp) and that is it.
About a week ago it started to make a sound that almost sounded like the starter grinding but the car would start and run fine once started. Fast forward to this weekend, I thought I had a leak from the crank seal so i pulled that out and replaced the crank seal. I looked at the starter and didn't notice any deformation on it as if it were grinding. Slapped everything back together and now am getting a horrible grinding or metal on metal sound, no start and when I get off the starter ( un-turn the key) I can hear pressure release from through the intake and can smell a bit of gas mixed with exhaust or almost like a super rich burning exhaust. I pulled the front three spark plugs (didn't have time to pull the rear three) and 2 of them had normal gap, but smelled like gas. The third was gapped to about .05 and also smelled like gas. When it was running, it ran fine and strong and had no issues at idle or while running. I drained all the oil and it has no coolant or metal flakes in it.
At this point I am at a loss and am reaching out to the people who may and do have more knowledge than me to get this issue resolved. If anyone has anything I should try or any tips as to where to start please let me know. Any help is greatly appreciated as the car is taking up the garage and I am borrowing a family members car until the monte is running again.
Again thanks in advance for any input.
Old Apr 19, 2021 | 09:50 AM
bump
Anyone got anything or at the very least a direction I should start in?
Old Apr 19, 2021 | 11:49 AM
So the only thing you changed between running to not running is the crank seal replacement?
I'd probably start in that area to see if anything looks odd. Not much in that area besides the crank sensor, but I'd check to make sure it's still plugged in and the wires didn't get damaged as that is pretty critical to function.
As for the grinding, I'd probably stick a ratchet on the crank bolt and start turning the engine over to see of you can isolate which area its coming from (or if it spins easily / cleanly, indicating that the noise may only occur with the starter engaged).
The one thing I'd check is to pull the inspection cover off the bottom of the trans and try to inspect the flexplate for cracks. Maybe its cracked bad enough that a chunk is dragging on something? Shouldn't cause a no start though unless the whole outer ring sheared off which ive never seen before.
Old Apr 19, 2021 | 12:29 PM
thank you very much. I will try those ideas today after work and see where it gets me. I'm hoping that the timing didn't get off some how and that the grinding is me just mangling the valves.
Goldie1
Jul 26, 2015 02:13 PM
hrg
Sep 6, 2013 01:10 PM
claude00
May 7, 2013 10:49 AM
claude00
Sep 22, 2009 07:52 PM
ajsbengals
Nov 11, 2007 03:30 PM
