Fuel Pump, Inline Filter, Water/ Methanol injection for Turbocharged 03 SS
Old Sep 2, 2011 | 07:08 AM
rlj4214's Avatar
Originally Posted by PacerSS
Someone correct me if I'm wrong here but I don't think there's anything stopping someone from using an L67 rail(billet log or similar) on an L36. The bolt locations should be the same if not easily modifiable. The fuel supply and return hookups should be as well. Now the only problem would be trying to run and 05/6+ returnless fuel system to it.
The injectors are supposedly at a different angle. That is why they specify which intake and heads or which swap kit in the case of ZZ Perf. At over $500 for the set I want whoever is making the to guarantee they fit before I lay down the bucks.
I really do wish you were correct, and you may be, but i figure that the people making them say they don't fit for a reason.
Thanks for your reply. Take Care.
Old Sep 2, 2011 | 07:57 AM
On clubgp.com you can usually find the SSM90 fuel rails for sale for around $200.
They aren't popping up everyday, but I do run by a few every now and then.
Old Sep 2, 2011 | 10:03 AM
rlj4214's Avatar
OK thanks. From what I understand those still require the blower lower manifold or heads due to a difference in the angle of the injectors.
I'm still not 100% sure what the differences are and whether or not it could be adapted.
Since it looks like I'm gonna be building an engine I guess it doesn't make that much difference but I'm sure there are others out there that would be interested, I could also be wrong, again, once more, sometimes, on occasion.
Old Sep 2, 2011 | 10:56 AM
PacerSS's Avatar
Well injector angle can really be adjusted with some pliers on the rail ears. lol That'd be what I'd do.
Old Sep 2, 2011 | 01:27 PM
rlj4214's Avatar
There has to be a reason why they say it won't work. That would be an easy fix but there has to be something else.
Give it a shot and let me know.
If somebody has done it I am willing to listen.
Thanks,
take care,
Ace25
Jun 19, 2013 08:38 AM
BUDDZZ
Jan 7, 2010 01:53 PM
drewskie043
Dec 21, 2009 08:19 PM
RocknSS04
Dec 1, 2007 06:10 PM
Brooke
Oct 17, 2007 04:35 PM
