Fuel leak
Old Feb 25, 2025 | 08:43 PM
myfurstcar's Avatar
Default Fuel leak
I hope all fellow forum members can spot the issues. Is it the fuel filter? my car is a fixer-upper and doesn't start, when I go to crank it fuel spills out of this part. Help please!!!
Old Feb 26, 2025 | 05:09 AM
Yes thats the fuel filter. You should be able to push that right most hose back on until you feel it click.
Old Feb 26, 2025 | 06:20 AM
I agree, the leak should be as simple as pushing the hose back in. Definitely inspect the female side for damage though as that shouldn't just fall off. I'd look around a bit to see if it got snagged on the line somewhere.
But... as you likely dont know the car's history, Id spend the $10 and put a new filter on it now. You're just 1 nut away and the messy part (draining the fuel) is clearly already done.
The one other thing - it should be tucked up tight to the body. Id look and see if theres a clamp the lines or filter should be sitting in when you're putting it back together.
Toby Lillie
Aug 6, 2016 07:58 PM
MJClemm
Mar 4, 2013 02:13 PM
artlawton
Jul 25, 2011 01:46 PM
PINKFLOYD_
Apr 7, 2010 10:22 PM
victoryred05
Jul 28, 2007 01:57 AM
